查看: 5320|回复: 7
ATMEL Studio升级到7.0.790
  • 签到天数: 1617 天
    发表于 2016-2-28 21:49:07 | 显示全部楼层 |阅读模式
    ATMEL Studio升级到7.0.790。主要更新有:
    Atmel Studio 7.0.790
    The following features are added in Atmel Studio 7.0.790:
    • Support for mass storage mode in embedded debugger (EDBG), enabling drag and drop
    programming.
    • Introduction of user interface profiles, the user can choose an interface where some of the toolbar
    buttons and menu items are removed.
    • Support for importing libraries to previously imported sketches. Added support for Arduino Zero and
    Zero Pro.
    • Parallell build turned on by default.
    Atmel Studio 7.0.790 resolves the following issues present in Atmel Studio 7.0.634:
    • AVRSV-7084: Persist user settings during upgrade.
    • AVRSV-7014: Some ATmega and ATtiny devices failed to start debugging with the Simulator.
    • AVRSV-7230: "Show all files" in Solution Explorer not consistent.
    • AVRSV-7062: Firmware upgrade of Xplained Mini kits not detected.
    • AVRSV-7164: Reading flash to .bin file created incorrect .bin file.
    • AVRSV-7106: Hex files with unix or mixed file endings fail to load.
    • AVRSV-7126: Databreakpoints for ARM should not be limited to RAM
    比较重要的有:
    • EDBG驱动支持拖放编程(为了更好的支持Mbed)
    • 默认使用并行编译
    • ASF自动升级到最新的3.30.1
    软件下载:
    游客,如果您要查看本帖隐藏内容请回复
    发表于 2016-4-4 16:34:14 | 显示全部楼层
    Studio升级到7.0.790 [修改]
    2016-4-19 14:05
    发表于 2016-4-19 14:05:33 | 显示全部楼层
    Studio升级到7.0.790
    发表于 2016-5-2 06:04:40 来自手机 | 显示全部楼层
    发表于 2016-5-17 21:35:33 | 显示全部楼层
    - -为什么官网找不到下载
    发表于 2016-7-30 15:14:13 | 显示全部楼层
    发表于 2021-11-25 10:46:29 | 显示全部楼层
    thank you so much
    GMT+8, 2024-6-3 01:01 , Processed in 0.159748 second(s), 29 queries , MemCache On.
